| | | Forums66 Topics128,005 Posts1,055,263 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 188 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 188 | Now that I've got a needle to replace the broken one, how do you go about attaching the needle back to the speedometer? Do you glue it on? I figured it would snap in, but it doesn't. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | all the years I've seen have a tiny post that sticks up from the speedo mechanism and the needles have a small socket in the middle that press fits onto that - what was your original like?
Bill | | | | | Joined: Jan 2011 Posts: 188 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 188 | It should be the same, but I never got it put on there the right way I think. The original was off of the guage when I got the truck. I'll keep trying. Thanks Bill! | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Could be the tip of the speedo is broke, so, the new one won't go on. | | | | | Joined: Apr 2008 Posts: 898 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 898 | Pin that needle goes on protrudes approx. 1/8" above speedo face if that helps.
Ed
