Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 38 guests, and 2 robots.
Topics128,003
Posts1,055,244
Members48,418
#945273 05/23/2013 2:24 PM
Now that I've got a needle to replace the broken one, how do you go about attaching the needle back to the speedometer? Do you glue it on? I figured it would snap in, but it doesn't.
all the years I've seen have a tiny post that sticks up from the speedo mechanism and the needles have a small socket in the middle that press fits onto that - what was your original like?
It should be the same, but I never got it put on there the right way I think. The original was off of the guage when I got the truck. I'll keep trying. Thanks Bill!
Could be the tip of the speedo is broke, so, the new one won't go on.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Pin that needle goes on protrudes approx. 1/8" above speedo face if that helps.
Ed
