| | | Forums66 Topics128,195 Posts1,057,380 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | awhile back I bought 3 apaches and a '53 GMC (still stock) in one fell swoop (they were going to be crushed). Since then I bought a '48 ford (same reason). so I have wads of old trucks with engines that may or may not run, some missing ignition switches (and wiring), some missing keys, etc. I really want to just see if they run (yes, have soaked cylinders for weeks now and turned over w/breaker bar on flywheel and cleaned plugs, rebuilt carbs, etc). Is there some simple way an idiot like me can crank and run them without ignition switches? I realize someone might prefer to PM me and not throw this out there, appreciate whatever you can offer. The things I'd like to crank for now is my positive ground 6 volt 53 GMC and my 12 volt 58 apache (has ignition switch intact, no key), and my '48 ford f3 (all there but no key). Surely there is some way I can use jumpers between battery and coil and what else?? thank you lefty | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | don't know about Fords, but with the foot starter all that's needed is the jumper from battery + to coil + and stomp the pedal - see a wiring diagramBill | | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | If it fails to crank then, do I need to pull starter and try to clean it out? I already tried on one '58 apache and none of that did anything (well, I did get to see the fuel gauge work and headlight/taillight), but no cranking. My buddy said it probably sat and was "open" field and I should tap hard on the case with a small hammer? Or, should I remove it and somehow clean it out? Never disassembled a starter before, never worked on a footstomp one either. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well, if the starter is hooked up and it doesn't function it's probably a starter problem, a rap with something may wake it up, or it may need pulling and bench testing, could be a number of problems, but they're pretty simple and there's info in the manualsBill | | |
