| | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I have a 48 3100 with the gas tank under the bed. I started putting the wood slats down over the tank in order to access nuts. Then I started from the other side. Now the middle board will not fit close to the cab and am trying to figure out what to do.
Any suggestions? Thanks
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I'm not clear on what your problem is. I also have a '48 and had trouble with the width of the boards. I wound up shaving a half inch off one of them. It sounds like you're having a problem with the length of a board, though. Is that the case?
I suggest putting all the boards and strips in without tightening the nuts. That way you can move everything around as needed to make it all fit. To do that, however, you'll probably have to lower the tank.
I saw a uTube video of one guy who put his entire bed togather off the truck, then positioned it on and bolted it down. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | It is the width.
Thanks for the response. I thought I could do it with the tank in place. And I also thought of shaving the one board down.
Thanks again
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, a "dry fit" is always a good place to start ... problem with shaving the sides of the boards is the spacing of the grooves for the skid strips needs to be just so or the skids won't lay right, and if yours is too tight just at one end the grooves won't be parallel, maybe you need to spread the bottom of the bed sides a bit at the front?
Bill | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | You are right. It is only at the front.
