1 members (baldeagle),
89
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 197 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 197 | I put a Stant #13358 in the truck, with a big 1/8" or so hole in it to flow some water when closed. Seems to be working so far; no big temp spike. It stayed at 175-185 like it should. I might try another one now without a hole (or with a small hole), if I do I'll report my results.
As a side note, I warmed up my other truck with an old brass 180 with no hole, which of course worked perfectly, as usual.
Some of my crap: 1963 C-30 flatbed dually 292/SM420 1965 C-10 LWB fleet 250/column shift 3 speed 1965 C-30 9' stepside 250/SM420/4.10 gears (my DD) Website I made for my crap: http://www.66submarine.com | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Heck, if its working why change it.... most Thermo's today come with a hole in them to help purge the air. Glad you got it going. I can sense your relief! | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Even though it does not have a hole in the flange a lot of t'stats have a small cut-out in edge of the butterfly to let a small amount of water pass.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2012 Posts: 197 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 197 | I'd like to try it to see if it works more than anything, still having trouble believing a USA Stant t-stat doesn't work anymore. I think a 1/16" hole should be all that's needed to bleed any air out. That's about all the ones that come with holes have. The brass one in my other truck, and the one that came out of this one had no bleed holes or notches in the valve and didn't spike. I'd like to run as small a hole as I can to avoid long warm up times, especially in winter.
Some of my crap: 1963 C-30 flatbed dually 292/SM420 1965 C-10 LWB fleet 250/column shift 3 speed 1965 C-30 9' stepside 250/SM420/4.10 gears (my DD) Website I made for my crap: http://www.66submarine.com | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | are you sure its made in the US? Levis aren't made in america anymore. There isn't a whole lot sacred any more. | | |
