0 members (),
40
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94450 01/27/2006 11:41 PM | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | I have a 1951 1/2 ton Total resto,New wiring harness 12 volt and brand new fuel guage 12 volt new sending unit also 12 volt. How do I test the electric hookup before I install everything.Does the guage have to be installed for self ground in the guage housing.I cannot seem to get the guage to read anything it came in the half full position and if I hook it up it stays there.I would welcome any advice you can call me collect 828-478-9248. Thanks Paul | | |
#94451 01/28/2006 2:26 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Everything has to be grounded. Be sure to run a ground strap from the sender to the cab. It won't properly ground to the tank. | | |
#94452 01/28/2006 3:20 AM | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | I have the sender grounded do I need to install the gauge in the cluster itself to ground the gauge. | | |
#94453 01/30/2006 12:52 AM | Joined: Nov 2004 Posts: 61 Member | | Member Joined: Nov 2004 Posts: 61 | Thump on the Gauge to see if it ain't stuck, had Jim carter redo a set for me and the gauge had to be thumped to get it to read and thumped when the key was off, also had no water temp either, it didn't work when I sent it to them for a complete rebuild, I'm guessing quality is hard to find anymore even when you pay a premium! | | |
#94454 01/30/2006 4:36 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | wodniw5, I notice your in N.C. but don't know what part. D&M Restorations is located in Greenvile N.C. Diane and Mike do great quality work and stand behind them. He has done work for me and a many I sent to him. He can do just about anything you want or modify. Just to let you know help is available somewhat locally. Send me a PM if you would like the phone # etc. | | |
#94455 01/30/2006 7:04 AM | Joined: Oct 2005 Posts: 35 Junior Member | | Junior Member Joined: Oct 2005 Posts: 35 | Hey wodniw5 check out this self test. If I recall correctly, an open circuit makes the gauge read past full and a closed circuit with no resistance reads empty. So disconnect the sending unit wire from the sending unit. Still half tank reading on the gauge? Then either there is electrical connectivity elsewhere or the gauge is faulty. How about removing the gauge cluster from the dash so you can access the terminals? Use a jumper wire from sending unit terminal to ground. Still no response then check the other wire. Either way, connecting to ground or no continuity in the circuit makes the gauge read to the extreme. Before you blame the gauge though, check the wiring. Use jumper wires if you have to, to simulate the wires in the harness.
Joe | | |
