3 members (baldeagle, Shaffer's1950, sron48), 52 guests, and 1 robot.
Topics128,015
Posts1,055,334
Members48,419
#944408 05/19/2013 9:52 PM
I have been fighting with my wipers and can't get it right. I found that on the first try I had the linkage on the wrong posts, Then I found that one of the posts was frozen and wouldn't swivel, Now I've got everything working fine, But I can't keep the spring retainer to stay on. Does anyone have any tips on how to go about putting them on? Thank you, Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
491ton #944467 05/20/2013 1:55 AM
I was having the same problem with the retainer not staying on so I used c-clips to hold the linkage in place.
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
491ton #944472 05/20/2013 4:58 AM
Hugh Spitler has a good Restoration Article in the Tech Tips Section under Windows called "Windshield Wipers (Slow Them Down)".
Like Slick69, Mr Spitler addresses the problem of keeping the arms on the spindles with the use of C-clips.
Dave
The Blue Funk: a '51 3100 4 OTF with a '57 235
More pix on Photobucket
491ton #944495 05/20/2013 9:29 AM
Ex Hall Monitor
Ex Hall Monitor
It's been a while since I removed/replaced the wiper linkage but if I remember right there are grooves in the part that the clips fit into. Make sure your clips are in those grooves and you should solve the problem.
491ton #944542 05/20/2013 12:53 PM
Like slick said
...c-clips...
491ton #944555 05/20/2013 2:16 PM
Ex Hall Monitor
Ex Hall Monitor
I never thought this would be an issue so I never considered anything but the stock clip. Wouldn't those C (some call them E) clips be a bit difficult to remove if you ever needed to once the wiper motor is in place?
491ton #944562 05/20/2013 2:40 PM
Sir Searchalot
Sir Searchalot
If the arms are aligned properly (as in perpendicular to shaft axis) and are not worn, the original spring clips will work. These are available new. ($2.50) Don't know if they are being popped off by misalignment or not in groove to begin with or spring is shot? But wrong arm on wrong place and frozen shaft points to misalignment/assembly problem. Those guys will stay on for a 100 years. Be sure that motor (I guess vacuum in your case) is mounted correctly and not crooked or missing a grommet/spacer.
491ton #944591 05/20/2013 5:11 PM
They are called E clips at the hardware store bin. And I imagine it would be hard to keep one that small from flying on removal. Best buy several and keep some on the shelf if you go this route.
491ton #944672 05/20/2013 10:21 PM
As you guys suggested I bought E clips and put them on my wiper motor The wipers work great and the linkage stays on. Thank you very much. I love the Bolt!!!
491ton #944725 05/21/2013 7:33 AM
The wiper motor is mounted with 2 screws, you might want to loosen the screws and adjust the motor so the arms square up.
491ton #945559 05/24/2013 4:17 PM
Glad to hear it worked!!
"IT IS WHAT IT IS"
In the DITY Gallery
1953 Chevy 1-Ton
