Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (WICruiser, Joe H), 148 guests, and 5 robots.
Topics128,283
Posts1,058,513
Members48,490
#94434 01/26/2006 10:05 PM
I was looking at a manual for a '47 Chevrolet pickup. They described a switch mounted on the starter and linked to the "stomper" that was called a ignition reversing switch. This switch reversed the system polarity through the points on run, I think, to reduce arcing and extend the point life.
I have never heard of this item..has anyone else!
Stuart
#94435 01/26/2006 10:20 PM
Yea,... I'm driving a stock 41' 1/2 ton that has it. as far as I know it still works. It might have been around earlier than that.
1941 AK named "PETEY" my buddy.
#94436 01/26/2006 10:55 PM
Ex Hall Monitor
Ex Hall Monitor
Boy Stuart, that's a strange one to me. While we're on the subject of strange bolt engineering, my 38 has an "octane selector". Ever see one of those? I never had.
#94437 01/26/2006 11:48 PM
Tiny,
I have never seen a octane selector. I had a '38 sedan (master?) with knee action suspension and that funny armored cable from key to coil.
Tweak,
Cool..how did you find out what it was and how it worked?
Stuart
#94438 01/26/2006 11:52 PM
the octane selector was a distributer advanceing/retarding thing - it's what they called the advance back then
#94439 01/27/2006 12:14 AM
My understanding of that switch on the side of the starter switch(mounted atop the starter) was to send full battery voltage to the coil during starter operation.Check your Chevy Duty catalog,I think they sell them.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#94440 01/27/2006 12:45 AM
That switch actually reverses the polarity of the current in the points, each time the truck is started. I bought a starter on Ebay a few years ago and it had one of those. There is an extra linkage to it. In reality it just presented something more to break down.
1951 1 Ton Completed
#94441 01/27/2006 2:45 AM
X
X Offline
Quote
Yep, those switches were eliminated late in the '48 model year "due to field maintenance problems".
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#94442 01/27/2006 2:53 AM
Ex Hall Monitor
Ex Hall Monitor
Bill is correct. It's a graduated adjustment on the distributor that allows you to advance or retard the timing by as much as 6 deg. This was to allow the owner to adjust to the variable quality of gas available then. Here is the best pic I have but it isn't a good one. You can see the setup at the base of the distributor cap. If you look close you can see the adjusting knobs & the pointer.
http://i47.photobucket.com/albums/f167/Tinys1938/Im001283.jpg
#94443 01/27/2006 5:05 AM
weird.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#94444 01/27/2006 7:10 AM
My dad's 1930 Fjord AA has an advance control on the steering column, opposite the hand throttle. The manual just calls it a "spark advance."
1954 GMC De Luxe COE
#94445 01/27/2006 11:50 PM
Stuart,... I found it on page 280 of the 41' shop manual. http://chevy.tocmp.com/1941shop/41csm280.htm . Tells a little about it too.
#94446 01/28/2006 1:56 AM
Tweak,
Pretty cool...who said GM engineers weren't smoking hemp on the job! eek
Stuart
#94447 01/28/2006 3:19 PM
Thanks Tweak,A picture is worth a 1,000 words!!This is not at all what I have seen.Mine was a terminal and pigtail wire off the side of the starter(stomp on me)switch that ran to the coil.
Wanted Good Woman:
#94448 01/28/2006 7:15 PM
gtow69,
I think your switch delivers 12 volts to the coil on start up only. I have seen those switches in the books, and just went to confirm it in Chev's of the 40's, but couldn't find it.
I think these were aftermarket items developed for folks with the stomp starter that have retrofitted to the 12 volt system. I might be all wet on this, but can't think of a 6 volt use for them. In the 6 volt arrangement, I don't think voltage is reduced to the coil.
Does your Studie have the V-8 in it? I remember these (327?) as being pretty spunky mothers!
Stuart
#94449 01/29/2006 6:36 PM
Yes Atomarc,but it is an orignal 259 cid with a (GM)two speed automatic.Reverse is where low is on a newer automatic.Fun car to drive and sorta snappy.Parts are costly and rare.
Wanted Good Woman:
