| | | Forums66 Topics128,052 Posts1,055,773 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | OK, so what's a good trick to lubricate the generator? I have a small squirt bottle of air tool oil I use but with the GEN in place, it's hard to get oil in it without making a mess. Do folks remove the GEN to lube it? Also, what are you using? I assume any light weight oil will work.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Any light engine oil will work. 3-In-One oil can or saved last drops of engine oil from oil changes. Your generator might have one or two lubrication "cups" (spring-loaded caps on top of a little filler tube) where a few drops of oil are dripped in once or twice a year. No muss, no fuss, if you only put in a few drops. After dripping in the oil, wipe around the spring-capped filler tube. Yes, you might need to use contortionist moves to get to the rear filler cup/cap. Some generators have no filler in the rear (no service lubrication). The rear cup/cap might have become eliminated in later generators because it was/is so hard to get to (except from underneath using a blind-fill move)? A rebuilt generator might also have sealed bearings in the front (no service lubrication, maybe - the re-builder will advise). | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Good thread, thanks for the info. Steve 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
