2 members (Rmillerfly, 1 invisible), 59 guests, and 2 robots.
Topics128,050
Posts1,055,757
#944471 05/20/2013 4:24 AM
OK, so what's a good trick to lubricate the generator? I have a small squirt bottle of air tool oil I use but with the GEN in place, it's hard to get oil in it without making a mess. Do folks remove the GEN to lube it? Also, what are you using? I assume any light weight oil will work.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Any light engine oil will work. 3-In-One oil can or saved last drops of engine oil from oil changes.
Your generator might have one or two lubrication "cups" (spring-loaded caps on top of a little filler tube) where a few drops of oil are dripped in once or twice a year. No muss, no fuss, if you only put in a few drops. After dripping in the oil, wipe around the spring-capped filler tube. Yes, you might need to use contortionist moves to get to the rear filler cup/cap.
Some generators have no filler in the rear (no service lubrication). The rear cup/cap might have become eliminated in later generators because it was/is so hard to get to (except from underneath using a blind-fill move)?
A rebuilt generator might also have sealed bearings in the front (no service lubrication, maybe - the re-builder will advise).
Thanks Tim.
David Gilmore
Stovebolt Pictures
Paint progress
1950 Chevy 3600
Good thread, thanks for the info.
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
