5 members (Goach2, Hotrod Lincoln, Gdads51, Sjm, greenie-reddy), 92 guests, and 2 robots.
Topics128,264
Posts1,058,352
Members48,485
#944413 05/19/2013 10:05 PM
I put a Stant #13358 in the truck, with a big 1/8" or so hole in it to flow some water when closed. Seems to be working so far; no big temp spike. It stayed at 175-185 like it should. I might try another one now without a hole (or with a small hole), if I do I'll report my results.
As a side note, I warmed up my other truck with an old brass 180 with no hole, which of course worked perfectly, as usual.
Some of my crap:
1963 C-30 flatbed dually 292/SM420
1965 C-10 LWB fleet 250/column shift 3 speed
1965 C-30 9' stepside 250/SM420/4.10 gears (my DD)
Website I made for my crap:
http://www.66submarine.com
Heck, if its working why change it.... most Thermo's today come with a hole in them to help purge the air.
Glad you got it going. I can sense your relief!
Even though it does not have a hole in the flange a lot of t'stats have a small cut-out in edge of the butterfly to let a small amount of water pass.
My Blog
I'd like to try it to see if it works more than anything, still having trouble believing a USA Stant t-stat doesn't work anymore. I think a 1/16" hole should be all that's needed to bleed any air out. That's about all the ones that come with holes have. The brass one in my other truck, and the one that came out of this one had no bleed holes or notches in the valve and didn't spike. I'd like to run as small a hole as I can to avoid long warm up times, especially in winter.
Some of my crap:
are you sure its made in the US? Levis aren't made in america anymore. There isn't a whole lot sacred any more.
