5 members (5 Window 9434, Jon G, John Dlugos, jmoore, moparguy), 96 guests, and 4 robots.
Topics128,120
Posts1,056,325
Members48,439
#942989 05/13/2013 8:32 PM
It seems I recall that Chevy used to have an ignition switch that you could turn to a position, take the key out and then the ignition switch would work as normal but without the need for a key. If I have it right the sides where the key goes in is raised so that you can grip it without a key in it.
Anyway, I remember one of my cousins from out on the farm saying that is what he had installed on his 63 GMC. Maybe he was pulling my leg and the ignition cylinder was just worn out??
Does anyone know what I am talking about? Ever heard of this?
Rusty64 #942996 05/13/2013 8:49 PM
Of course. My '48 has one. With the key in the ignition, turn the key to the right, remove it, and you can turn the ignition back to center and start it without the key. with the key in the ignition, turn it to the left and remove the key, and the ignition is locked. I don't know about the second series AD's, but the '47-54's work like this.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Tom R #942998 05/13/2013 8:54 PM
My '48 Chevy 1/2 ton has this type of ignition switch as well. It certainly is the product of a simpler time and place in our country's history. A neat little feature actually! Jim Carter has posted an article on this topic.
http://www.oldchevytrucks.com/blog/index.php/2010/02/ignition-switch-changes/
ENJOY!
Rusty64 #943055 05/14/2013 1:50 AM
My '56 has it. My '54 burb and '53 yard dog don't.
Rusty64 #943097 05/14/2013 9:00 AM
My Corvair had that type of switch. Unless you turned to the switch to the "locked" position, the switch could be used without the key.
Rusty64 #943258 05/14/2013 10:02 PM
Good to know that it does exist.
Does anyone know if that was an option on the early 60's trucks.
Or can I adapt my ignition switch to operate this way?
Rusty64 #943265 05/14/2013 10:14 PM
Very common in early GM vehicles. All of Dads Buicks had that type switch until at least '56. Never locked them and we lived in OKC. Only time the car was stolen was when my brother and I did it in the middle of the night.
Rusty64 #943391 05/15/2013 12:17 PM
Came standard on early 60's Chevrolet Corvair Trucks. (are they really stovebolts?)
Rusty64 #943409 05/15/2013 1:13 PM
I had a Corvair van and it had a distant relative of the stovebolt six - a pancake six (hard to believe that it leaked more oil than an stovebolt).
Rusty64 #943448 05/15/2013 5:33 PM
Ex Hall Monitor
Ex Hall Monitor
The old GM ignition cylinders are prone to wear so many of the type that don't have that feature can still be turned without a key. My old '55.1 panel was that way. I used a can opener (church key) to operate my ignition.
Tiny #943712 05/16/2013 8:06 PM
My 62 vette had that. Half the time I wouldn't even take my keys.
Tiny #943801 05/17/2013 8:38 AM
My '66 has the original ignition switch and it's that way. drive
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Rusty64 #944390 05/19/2013 8:56 PM
All good info guys.
Thanks.
I think I am going to have mine set up that way. After all the work I did painting the interior I want to keep it looking good and not have the paint scratched by the key chain.
Rusty64 #944479 05/20/2013 7:41 AM
back yard wrench turner
Install a hidden kill switch to deter unauthorized use.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Yeah, for sure. These days are not the 50-60s.
I like a latching relay operated by a hidden momentary switch.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Rusty64 #949458 06/10/2013 9:55 PM
Went to a bone yard this last weekend and found an ignition switch that has this feature. It is not from a truck (has a dash light receptical built into the housing). However it does work as we have been discussing.
I tried to put its tumbler in my ignition housing and the feature goes away.
If I put my tumbler in its housing the feature still works.
So my study has determined that it is the housing that allows this feature.
So now I either need to trim the light receptical from this new housing or find a workable truck housing or figure out how to modify my existing truck housing.
Rusty64 #949473 06/10/2013 10:33 PM
The switch and the lock are two separate entities. Why can't you install the switch with light hole in the truck?
Rusty64 #949478 06/10/2013 10:57 PM
I can but it means cutting off the light hole and installing a non-original switch.
Not really a big deal I suppose.
