7 members (1955 1 Series, Wayne67vert, Brian Moore, Jon G, KEVINSKI, 50Chevy3100, 1 invisible),
50
10
Mod | | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | It seems I recall that Chevy used to have an ignition switch that you could turn to a position, take the key out and then the ignition switch would work as normal but without the need for a key. If I have it right the sides where the key goes in is raised so that you can grip it without a key in it. Anyway, I remember one of my cousins from out on the farm saying that is what he had installed on his 63 GMC. Maybe he was pulling my leg and the ignition cylinder was just worn out?? Does anyone know what I am talking about? Ever heard of this? | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Of course. My '48 has one. With the key in the ignition, turn the key to the right, remove it, and you can turn the ignition back to center and start it without the key. with the key in the ignition, turn it to the left and remove the key, and the ignition is locked. I don't know about the second series AD's, but the '47-54's work like this. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | My '56 has it. My '54 burb and '53 yard dog don't. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | My Corvair had that type of switch. Unless you turned to the switch to the "locked" position, the switch could be used without the key. | | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | Good to know that it does exist. Does anyone know if that was an option on the early 60's trucks. Or can I adapt my ignition switch to operate this way? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Very common in early GM vehicles. All of Dads Buicks had that type switch until at least '56. Never locked them and we lived in OKC. Only time the car was stolen was when my brother and I did it in the middle of the night.
| | | | | Joined: Aug 2005 Posts: 276 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 276 | Came standard on early 60's Chevrolet Corvair Trucks. (are they really stovebolts?)
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I had a Corvair van and it had a distant relative of the stovebolt six - a pancake six (hard to believe that it leaked more oil than an stovebolt).
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The old GM ignition cylinders are prone to wear so many of the type that don't have that feature can still be turned without a key. My old '55.1 panel was that way. I used a can opener (church key) to operate my ignition.
| | | | | Joined: Oct 2012 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 58 | My 62 vette had that. Half the time I wouldn't even take my keys. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | My '66 has the original ignition switch and it's that way.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | All good info guys. Thanks. I think I am going to have mine set up that way. After all the work I did painting the interior I want to keep it looking good and not have the paint scratched by the key chain. | | | | | Joined: Sep 2010 Posts: 1,700 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,700 | Install a hidden kill switch to deter unauthorized use. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Install a hidden kill switch to deter unauthorized use. Yeah, for sure. These days are not the 50-60s. I like a latching relay operated by a hidden momentary switch. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | Went to a bone yard this last weekend and found an ignition switch that has this feature. It is not from a truck (has a dash light receptical built into the housing). However it does work as we have been discussing. I tried to put its tumbler in my ignition housing and the feature goes away. If I put my tumbler in its housing the feature still works. So my study has determined that it is the housing that allows this feature. So now I either need to trim the light receptical from this new housing or find a workable truck housing or figure out how to modify my existing truck housing.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The switch and the lock are two separate entities. Why can't you install the switch with light hole in the truck? | | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | I can but it means cutting off the light hole and installing a non-original switch. Not really a big deal I suppose. | | |
