| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94431 01/25/2006 9:27 PM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Not sure if this is where I should post this or not, but here goes...
The '63 is coming into the garage in the next month or so to get a new (to me anyway) engine and probably a transmission rebuild. I got to thinking about something else while I was planning the shop time. Could I replace the original heater controls with something up to date (preferrably electric)? It doesn't have A/C, and I don't really care, but the heater/defroster doesn't put out very much and the controls can be difficult to move. Has anyone done this already? If so, did you end up with something that you liked or was it an abortion you wish you'd thought twice about? | | |
#94432 01/26/2006 12:08 PM | Joined: Jan 2005 Posts: 24 Junior Member | | Junior Member Joined: Jan 2005 Posts: 24 | Old Air products here in Ft Worth should be able to supply you with everything you need to refresh your current stuff. They sell nice new cables to replace your stiff current ones. Between new cables and rebuilding your stock controller, you should see much nicer results. They worked fine when they were brand new.
Tender caretaker of antique tractors and old trucks.
#94433 01/26/2006 3:47 PM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Tx, you got a link or contact info? | | |
