7 members (klhansen, 87GN, tclederman, Stovebolt48, Peggy M, baldeagle, 1 invisible), 117 guests, and 1 robot.
Topics128,048
Posts1,055,666
#944257 05/19/2013 10:59 AM
Just got my rebuilt 235 back in and running after the usual can of worms - old fuel pump broke the lever, fished the piece out of the pan - fuel line broke changing out the fuel pump - replaced it from the tank to the pump, started up and runs strong! But there is a obvious noise that I thought might be the water pump. Runs cool and the noise is noticeably louder at 55 mph. Now here the puzzler...it gets louder when I stop and put on the parking brake! Any thoughts on this? Truck is an all original 46 1/2 ton with a 61 235.
Anzan #944260 05/19/2013 11:07 AM
How about taking a video of the sound? That would help. Best way to eliminate the possibility of the water pump, generator, etc.. is to remove the fan belt and try it.
Nice looking truck.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Anzan #944262 05/19/2013 11:17 AM
DMG, I was going to do the fan belt thing until I realized it got noticibly louder when I engaged the parking brake. I don't think it's the pump, it's only three years old with about a 100 miles on it. I was thinking about loosening up the motor mount bolts, starting it up, move it forward and back and retighten. It's the parking brake part that's puzzling!
Anzan #944264 05/19/2013 11:24 AM
The parking brake linkage pulls the engine and transmission towards the rear when engaged.
It is possible that the harmonic balancer is hitting on the front mount.
My Blog
Anzan #944267 05/19/2013 11:33 AM
I'll check that out and get back on this. Thanks
Anzan #944995 05/22/2013 10:47 AM
Bingo Dave! The metal grease shield that rides on top of the front motor mount was touching the harmonic balancer. You can see daylight thru the metal shield where it was rubbing! The 216 that I replaced in '92 didn't have that piece and neither did the '55 235 that went back in. Trying to do everything right this time we installed it like original but I guess the '61 235 didn't like it there! Gone now and although I haven't run it yet I'm pretty sure that was the cause of my 'curious noise'. Thanks for the insight guys, this forum rocks!
Anzan #945136 05/22/2013 9:35 PM
Personally I think that shield is useless. That is because any oil that runs down on top will go through the bolt holes and get to the rubber. I got rid of mine too as it made putting the pan on a horrible task.
By the way that is a pretty awesome looking truck. It is almost too nice to drive!
1951 1 Ton Completed
Anzan #945139 05/22/2013 9:41 PM
Internet Diagnosis and nailed it.
darn Dave you are good.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Anzan #945149 05/22/2013 10:09 PM
Just been at this a long time.
My Blog
That shield was it for sure. Took her for a long drive today and it was really quiet till about 50mph and then a slight vibration kicked in. Nothing serious but noticible. I'll get to put a timing light on the new engine on Friday and will see how close the timing is. Might be the cause of the roughness. The new HEI dist. and Fenton headers should be a real plus to the old girl. Thanks to Dave and all you guys for the help and compliments. BTW, my bride picked the color combination...maybe Coors will send me a free beer!
Anzan #945185 05/23/2013 2:46 AM
That is a striking truck!
You better keep her! The bride that is dance.
My Blog
I drove her to our wedding in this truck in 1976! They are both keepers!
