Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Otto Skorzeny, carbking, tclederman), 152 guests, and 4 robots.
Topics128,284
Posts1,058,526
Members48,490
All of a sudden the rear lights stopped working. Where do I start looking for the problem? The running lights work fine. It was all working a few weeks ago. Any suggestions?
1958 Chevy 1/2 ton Apache Stepside Longbed
Never trust a driver with a collision shop courtesy car
Photo Album
magnolia,
To get net on the problem, it's either electrical or mechanical. The brakes and turn signal are a single circuit. Are you saying you have taillights, but no brake lights or backup lights.
The backup lights are not connected directly to the brake circuit...unless they might share a common fuse. After checking fuses, I would crawl around under the truck and look for mechanical damage.
I am not sure the brake light circuit is fused. It is connected to the flasher, and it does go through a switch of some sort.
A inexpensive 12v tester is very handy for problems like this. Grab a wiring diagram for your year truck and see if there is any common denominator between these failed items.
Stuart
Thanks atomarc. My father suggested we start at the simplest point and he was right. He checked the light bulbs. The same filament in both bulbs went at the same time. I was all ready and focused to find where there could be a break in the line. I still haven't figured out what's wrong with the reverse/backup lights yet. Later.
Photo Album
magnolia,
Outstanding...isn't it funny how we overlook the obvious. Tell your father he is very wise! smile
Stuart
Check the bulbs. I had about a yard of gravel dropped all at once into the bed of my 1/2 ton by a big frontloader. All my rear lights quit working and I figured it broke a wire. Wrong! The impact of the load hitting all at once broke the filimants out of the brake and backup lights at the same time.
52Ted
illegitimi non carborundum
