1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#94390 01/22/2006 6:30 PM
Junior Member
Junior Member
Has anyone had any luck with the hidden antennae?
I got one and installed it for the 'clean look' and cant pick up a station when the stereo 'seeks'. about to toss it in the trash!
#94391 01/22/2006 8:06 PM
interesting - what type is it and where is it mounted? does it work when you manually tune a station in? I've never had one but have seen them used on rods I've seen at shows
#94392 01/23/2006 2:59 AM
Is it at least 30 inches long?
Certainly, those little mini-things are always worthless.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#94393 01/23/2006 2:37 PM
Good question 65, I'm thinking of putting one in and I've heard they work well but would like to hear it from someone who's got one installed. Or did have one...
Larry Bear
55.5 Chevy 3100 Panel
#94394 01/23/2006 6:52 PM
Junior Member
Junior Member
Antennae cord is really long, about to try to install on back window. Have it under dash now and cant manually get a station either.
65shorty
#94395 01/23/2006 7:17 PM
Alan - quality does has some relevance, but them 'mini-things' are electronically tuned, just like the antennas on aircraft and spacecraft, physical size doesn't matter
where I've seen'em is mounted under the running boards on hot rods - works there, but no tellin what make they were - have you tried talking to the maker?
#94397 01/24/2006 10:04 AM
I am putting an antennae on my back window this week.
"will let you know how it works."
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#94398 01/24/2006 12:32 PM
The last antennae I used was from a motor cycle. (used in the front furrin section)It was the type that had about a 3' main line and 2 ears that went out along the roof where I had my overhead console. , when I moved the radio to the dash I just mounted the ant. ears along the inside of the firewall under the dash out of site.
There is also a co. now called secretaudio that has a "hidden" ant. but my motor cycle ant. worked great
Good Luck, bowtie
