1 members (Woodcmiami),
72
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94390 01/22/2006 6:30 PM | Joined: Nov 2005 Posts: 16 Junior Member | | Junior Member Joined: Nov 2005 Posts: 16 | Has anyone had any luck with the hidden antennae? I got one and installed it for the 'clean look' and cant pick up a station when the stereo 'seeks'. about to toss it in the trash! | | |
#94391 01/22/2006 8:06 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | interesting - what type is it and where is it mounted? does it work when you manually tune a station in? I've never had one but have seen them used on rods I've seen at shows
Bill | | |
#94392 01/23/2006 2:59 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Is it at least 30 inches long?
Certainly, those little mini-things are always worthless.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#94393 01/23/2006 2:37 PM | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Good question 65, I'm thinking of putting one in and I've heard they work well but would like to hear it from someone who's got one installed. Or did have one... | | |
#94394 01/23/2006 6:52 PM | Joined: Nov 2005 Posts: 16 Junior Member | | Junior Member Joined: Nov 2005 Posts: 16 | Antennae cord is really long, about to try to install on back window. Have it under dash now and cant manually get a station either. 65shorty | | |
#94395 01/23/2006 7:17 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Alan - quality does has some relevance, but them 'mini-things' are electronically tuned, just like the antennas on aircraft and spacecraft, physical size doesn't matter
where I've seen'em is mounted under the running boards on hot rods - works there, but no tellin what make they were - have you tried talking to the maker?
Bill | | |
#94397 01/24/2006 10:04 AM | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | I am putting an antennae on my back window this week. "will let you know how it works."
Cliff59 | | |
#94398 01/24/2006 12:32 PM | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | The last antennae I used was from a motor cycle. (used in the front furrin section)It was the type that had about a 3' main line and 2 ears that went out along the roof where I had my overhead console. , when I moved the radio to the dash I just mounted the ant. ears along the inside of the firewall under the dash out of site. There is also a co. now called secretaudio that has a "hidden" ant. but my motor cycle ant. worked great Good Luck, bowtie | | |
