5 members (60steve, Alex52, Gdads51, 2 invisible), 76 guests, and 0 robots.
Topics128,212
Posts1,057,465
Members48,471
Junior Member
Junior Member
Does anyone have a wiring diagram that will show the component location and wiring on a 54-56 Chevy Truck? I have a 53 taht is partially converted to 12 volt but the wires are a hangin and I dont know where they are go. I bought it this way and I have gotten it to run but I dont have want I need to correctly remount the fuse pannel and other areas are a puzzle. Thanks for your help.
Socket Breaker
Socket Breaker
you wrote you were looking for '54-'56 information...
You have a '53... the '53 is different from a '54-'55 truck...
the body style went '54-'55 1stseries, then '55 2nd series was an all new truck, body wise... check the gallery section for plenty of pictures for examples.
this is for a 1955 second series:
http://chevy.tocmp.com/1955truck2shop/index.htm
Do you have a later model engine in your truck?
the 6 volts stopped in the 55 1st series or was it the '54? - I know the '55 2nd series was a 12 volt unit... someone around here knows.
-W
Ex Hall Monitor
Ex Hall Monitor
Try here: http://chevy.tocmp.com/chevywiring/index.htm
There's a '54 truck diagram listed. It should be very close to your '53.
