0 members (), 171 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
I have a casting number GAMI60566. The only thing I can figure out is it might be a 1948
I just got a 1948 3100 short bed 5 window today with this motor and it has a bent push rod
The odd thing is I have a 1949 216 out of a 3600 long bed and the push rods are a different size. Anyone heard of this. Cars different then trucks?
Post the engine serial numbers for both engines. It is pressed into the block to the rear of where the distributor enters the block. There were different length push rods.
here is the number on my 1949 3600 truck. AGCA567080 Thinking it must be the 235ci
I found my answer. My 1948 3100 has a car motor 216 and my 1949 3600 has as a truck 216. Push rodes are different legths between the two. Interesting fact
If the push rods are only 1/8" different in length, the longer ones are 235.
My Blog
