| | | Forums66 Topics128,142 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 31 New Guy | | New Guy Joined: May 2012 Posts: 31 | I have a casting number GAMI60566. The only thing I can figure out is it might be a 1948 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2012 Posts: 31 New Guy | | New Guy Joined: May 2012 Posts: 31 | I just got a 1948 3100 short bed 5 window today with this motor and it has a bent push rod | | | | | Joined: May 2012 Posts: 31 New Guy | | New Guy Joined: May 2012 Posts: 31 | The odd thing is I have a 1949 216 out of a 3600 long bed and the push rods are a different size. Anyone heard of this. Cars different then trucks? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Post the engine serial numbers for both engines. It is pressed into the block to the rear of where the distributor enters the block. There were different length push rods. | | | | | Joined: May 2012 Posts: 31 New Guy | | New Guy Joined: May 2012 Posts: 31 | here is the number on my 1949 3600 truck. AGCA567080 Thinking it must be the 235ci | | | | | Joined: May 2012 Posts: 31 New Guy | | New Guy Joined: May 2012 Posts: 31 | I found my answer. My 1948 3100 has a car motor 216 and my 1949 3600 has as a truck 216. Push rodes are different legths between the two. Interesting fact | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If the push rods are only 1/8" different in length, the longer ones are 235.
See the USA in your vintage Chevrolet! My Blog | | |
