0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94290 01/17/2006 12:08 PM | Joined: Nov 2005 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 23 | I have an un-opened 12 volt wiring harness kit for my 1949 3600 which I would like to trade someone for a new 6-volt harness for the same truck. I have decided to keep the truck 6-volt and do not need the 12-volt wires.
IF anyone is interested in trading, or can simply point me to a vendor who would sell a 6-volt harness, I would appreciate a note.
Thanks, Spencer | | |
#94291 01/17/2006 2:19 PM | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | | | |
#94292 01/17/2006 4:11 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Nearly all resellers buy their harnesses here. Skip the middleman: http://www.ynzyesterdaysparts.com/ Excellent product.
#94293 01/17/2006 7:58 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Are you making the distinction between a 6 volt harness and a 12 volt harness strictly the wire gauge?
Stuart | | |
#94294 01/17/2006 8:45 PM | Joined: Nov 2005 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 23 | Maybe? I really do not know what the difference is? I just have decided that I am not going to use the 12 volt harnes I have. It has much more than what I need. | | |
#94295 01/17/2006 9:01 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the difference would be any 'extra' circuits in it, like for alternator and accessories - what you want is an original style harness - no extra circuits and designed for a 6V system [which uses some wires heavier gauge than 12V], and a generator - just need to get that from any supplier, and list your '12V' harness in the swap section, saying what extra circuits it has
Bill | | |
#94296 01/17/2006 9:26 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Usually, the difference between a 12v and a 6v harness is the gauge of the wire.
6v uses heavier gauged wires (ie, where you use 18awg on 12v, you'd use 16awg on 6v). Either gauge of harness may have hookups for various other things like blinkers, horn relays and whatnot. | | |
#94297 01/18/2006 1:25 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Brendan,
What's a Whatnot? :p
6V-Stu | | |
#94298 01/18/2006 6:10 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Stu:
It's code for thingamajiggers. | | |
