| | | Forums66 Topics128,034 Posts1,055,544 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 42 New Guy | | New Guy Joined: Oct 2009 Posts: 42 | What should I do about choosing a driveshaft? One-piece or two-piece? Like to go one piece. Truck had original two-piece which I removed along with old 4-speed box, that's now a 5-speed. With the slip yoke in place and pulled back 3/4 - 1", I'm left with about 64-ish inches to bridge. I'm not entirely sure if engine hp/torque and rearend set up have any bearing on this matter. If they do it's a 350 with bolt-ons perhaps 350hp ( perhaps 400 in a crowd) and probably a similar number for lbs/ft. Rearend is 12-bolt limited slip. Anyone out there able to throw light on this subject? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If you have a "driveline" shop around then visit them and ask for their recommendation. I work part time for Carolina Driveline and Tom has been doing this for over 30 years. From tractor trailers to rock crawlers he can build about anything. It all plays a part in what you need so decide how you want it to be. You could go aluminum, steel and a couple other ways to get what you want. I can say he converts a lot of 2 piece to one piece driveshafts but again, depends on what you want to do. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | I am new here. I have a 65 c10 long bed with a 700+hp small block and the stock 2 piece. I drive it on the street every weekend. It holds up fine. Big rigs have 2 piece driveshafts and 1800 ftlbs of torque. Mines never bound up or anything. I also cant get traction to save my life. Just my 2 cents.
