0 members (),
95
0
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Finally ready to begin assembly of 261 caddy stroker! The only thing I haven't planned for is the cam. The engine will have a McGurk 2 x 1 with 2 Stromberg singles. I won't be racing, I just want most efficient power at lower rpm for highway driving and occasional towing. I will be using current sm420 tranny with gear vendors od. Suggest away!!! | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I'd run this question past Tom Langdon of Langdon's Stovebolt, I'm sure he can steer you in the right direction re. cams. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | camcraft and howard cams will grind nearly anything might want, I'm pretty sure the fella at camcraft said he does the cams for Tom Langdon, and Patricks,(But don't hold me to it) either way, any one of the above mentioned people can talk you through it. | | |
