Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 95 guests, and 0 robots.
Topics128,274
Posts1,058,433
Members48,490
Finally ready to begin assembly of 261 caddy stroker! The only thing I haven't planned for is the cam. The engine will have a McGurk 2 x 1 with 2 Stromberg singles. I won't be racing, I just want most efficient power at lower rpm for highway driving and occasional towing. I will be using current sm420 tranny with gear vendors od. Suggest away!!!
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
I'd run this question past Tom Langdon of Langdon's Stovebolt, I'm sure he can steer you in the right direction re. cams.
1946 1/2-Ton Chevy
camcraft and howard cams will grind nearly anything might want, I'm pretty sure the fella at camcraft said he does the cams for Tom Langdon, and Patricks,(But don't hold me to it) either way, any one of the above mentioned people can talk you through it.
