5 members (Ponchogl, walter74, 55shaker, ronsway, 1 invisible), 179 guests, and 9 robots.
Topics128,089
Posts1,056,138
Members48,435
The Blue Funk (See my signature) was in an MVA and suffered a broken carb base. I replaced the base with one that I thought was similar.
Recently, I was able to get spark to the plugs. The engine was cranked, came close to sounding like it was going to turn over, but never did. A bit of gas was noted to be leaking betweeen the bowl and base. The screws were tightened but that changed nothing.
Figuring I was going to have to at least put a new gasket in, if not do a total rebuild, I removed the carb and separated the base from it. It was then that I noted the bore in the base is 1" and the bore in the bowl is 3/4".
What kind of information can you give me?
Thanks.
Dave
The Blue Funk: a '51 3100 4 OTF with a '57 235
More pix on Photobucket
Here's an interesting post I found on a search:
Originally Posted by Tomcoe
The seaping gasket is evidence that the float is set just a little too high. Gas shouldn't "rest" on the gasket. It should rest below the gasket just slightly or any gasket on any carb will seap. They aren't "liquid tight". Just resistent to sloshing and keeping gunk out.
Dave
