| | | Forums66 Topics128,093 Posts1,056,154 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | Does anyone know where one can find a good quality drivers side door latch for a 1948 1/2 ton. I now know that the Counterparts brand is not the quality I am looking for. Mine is wore beyond repair without a fair amount of welding and filling. Other posts state there are no re-manufactured units out there but thought I would ask if that may have changed. I fear purchasing an original used one from E-bay would get me another wore out unit.
If you never tell a lie, you never need to remember what you said.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a post in the parts wanted might be better than e-bay, and would probably find one
Bill | | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I found a supplier on e-bay, Classic Chevy Truck Parts, that has a new repo drivers side door latch that looks and works as good as the original. I have it installed and everything is good. I do have to slam the door but after working on it I can see the door itself is not in line. It touches the cab weather strip at the top and the bottom but not in the middle unless I slam the door, then everything looks good. I am going to try to straighten the door out and that should solve my problem.
