0 members (), 155 guests, and 4 robots.
Topics128,110
Posts1,056,241
Members48,437
#942435 05/11/2013 11:21 AM
Does anyone know where one can find a good quality drivers side door latch for a 1948 1/2 ton. I now know that the Counterparts brand is not the quality I am looking for. Mine is wore beyond repair without a fair amount of welding and filling. Other posts state there are no re-manufactured units out there but thought I would ask if that may have changed. I fear purchasing an original used one from E-bay would get me another wore out unit.
If you never tell a lie, you never need to remember what you said.
a post in the parts wanted might be better than e-bay, and would probably find one
I found a supplier on e-bay, Classic Chevy Truck Parts, that has a new repo drivers side door latch that looks and works as good as the original. I have it installed and everything is good. I do have to slam the door but after working on it I can see the door itself is not in line. It touches the cab weather strip at the top and the bottom but not in the middle unless I slam the door, then everything looks good. I am going to try to straighten the door out and that should solve my problem.
