0 members (),
40
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | For making door panels,would the retainers in the link work ok? Plan on making the panels out of the abs like I was reading on here and drilling the holes where the retainers will go, and I noticed the retainers have 2 heads. Could I just cut the top head of the retainer off and push the retainer thru the panel and glue it in place....then cover the panels with whatever fabric? Or maybe someone could share an idea of what to use so that there are no screws or anything visible. http://www.clipsandfasteners.com/Door_Panel_Retainers_Clips_GMC_p/pas1716-100.htm | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Doesn't the top head compress onto the bottom head as you push in the clip?
Drew
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | That top head is designed to screw in to a hole. This way the the panel is sandwiched between the two "heads". If you ABS is 1/8" thick or so, the clips should work just fine. Get a scrap piece of ABS and drill a progressively bigger hole until the clip fits/works. Then, with all your holes drilled in your panel, place the panel on the door and mark / drill the corresponding holes which will be a slightly smaller diameter than your barbed shaft. Every 8-10" should work and the corners. Maybe even some in the middle of the panel in strategic places. After you cover your panel in fabric, you'll have no visible clips. And, if they break, they are easy and cheap to replace. It does help to have the specific fork tool to help remove the panel when you need to. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | | | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Thanks MNSmith....great info | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....another idea would be to use Vel-Cro | | |
