0 members (),
99
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Well, I tried it and it turned out much better than expected.  Pics on my home page.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Wow! Looks great!!! Especially Black!!! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Details: The whole truck? Semi Gloss? Thinned? coats?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Looks great Robert. Looks like it flowed out nicely, good reflection in the paint.
John | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I sprayed it on rather than rolling like I've seen in the past. I saw someone on YouTube who'd sprayed it and thought I'd give it a try. But I did have issues, not with the paint itself, but with the cheap@$#% Harbor Freight gun. I never could get the paint flow quite right. Halfway through the first side, the *%$#)% fell apart! Literally!! The flow set screw came flying of the back of the gun! I had no Idea where the darned thing went so I made a mad dash back to the store to get a new one. I thought that I'd just buy the the cheaper $15 gun and just get the set screw rather than buying another $40 one because they looked just alike..... NOT!! Got home and they were totally different! Didn't want to drive back to the store so I figured I may as well try it. It was also at this point that I realized that I'd also forgot to use the water filter I'd bought the first time. Man what a lethal combination!!! The gun leaked paint like a sieve and the filter leaked water and ruined my hard work. The paint it self looked AWESOME, if you didn't look at the obvious air bubbles and the globs of dripped paint!!! (which also ruined the garage floor!!) Sanded down the bad spots and went to Home Depot and found a much better gun. shot it again with the new gun and it turned out great. No issues this time.... almost. Right at the start the threads on the plastic water filter stripped and it blew off showering the paint with Teflon tape fragments!! A quick trip to the local auto parts store solved that. They had a metal one that was perfect. The Home Depot gun worked flawlessly right out the box!!!
As far as the paint goes, I used a gallon Rustoleum Professional series gloss black thinned with 2 pints of acetone. I applied about three coats all together. There are a couple of runs I need to deal with, but overall I'm a happy camper!!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Nice results Gives us Home garage painters hope | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I've never tried thinning it with acetone before. I always use their thinner or most of the time mineral spirits for thinning..... Seems like anytime you get a paint gun out there can be trials.....I was spraying Rustoleum Sunrise Red on a project one time, that color must attract knats, I must have had hundreds stuck in the first coat. Was no use trying to go on, I wiped it down and waited till another day. Usually I carry a roll of masking tape in my pocket, if I get a knat or bug, I make a tape ball and gently lift out the offender..... John | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I've never tried thinning it with acetone before. I always use their thinner or most of the time mineral spirits for thinning..... I had thinner in my shopping cart, then I read the instructions on the paint can & it said to use acetone.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Robert,
You are 'Paint Hero' in my book, great job!!! The story of your trials w/ the guns and filters is amazing! Thanks!
Regards,
Cosmo
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | | | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | What model gun did you end up using from Home Depot? | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I don't think I've ever used the Professional series paint before in the gallons. I've always just used the regular quarts available at the store.....
John | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | What model gun did you end up using from Home Depot? Husky gravity feed HVLP model 762-051 I don't think I've ever used the Professional series paint before in the gallons. I've always just used the regular quarts available at the store.....John You can find them all over the place, Home Depot, Lowes, even Walmart.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Looks great! I might have to try that when the time comes. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Looks good in the photos. Let it dry for a week or more and then shoot with automotive (catalyzed) clear. Otherwise, the paint wont last very long. | | | | | Joined: Sep 2011 Posts: 82 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 82 | Looks great! You give me hope. What seats do you have in her? | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Looks great! You give me hope. What seats do you have in her? I can't remember the exact year, but I believe they're from a '00 or so Silverado.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | Looks great Robert! Are you concerned about the durability? Will it be as hard as a two part paint with hardener? I am thinking of painting my truck with a two part (well three with paint, hardener, reducer.) I am going to use a small gun that my air compressor handles. It is only for touch up, but I am thinking if I do a panel at a time I will be OK. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Looks great Robert! Are you concerned about the durability? Will it be as hard as a two part paint with hardener? It's not as hard as regular paint, but I haven't shot any clearcoat on it yet.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Ted, I don't know if a touchup gun will throw enough paint over a big enough spray pattern to give good coverage or not? usually they don't throw out enough paint for a large panel job, and with a narrow pattern you might more likely see "striping" in the passes. I guess try it on one panel and see what results it gives you.
John | | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | You may be right John. I can practice on my hood. I may be able to use a bigger gun now that I have a better compressor. But it is still less CFM than recommended.
Robert, if you are going to clear-coat it it should be no problem. At our paint supplier they told me the first coat is not UV resistance and not durable. The second coat should button it up nicely! | | |
