1 members (Rusty Heaps),
116
0
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94193 01/06/2006 8:28 PM | Joined: Nov 2005 Posts: 16 Junior Member | | Junior Member Joined: Nov 2005 Posts: 16 | Hello to all,
Have a problem, dead truck! replaced alternator, external voltage regulator and battery. Still no juice to even crank. Is the starter next?
Thanks | | |
#94194 01/06/2006 8:47 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 65shorty,
Welcome to the site...half of your state is here!
Your profile indicates a '65 truck, so I am guessing a key switch and standard transmission. If you have replaced all those items and no soap on the start, it's time to troubleshoot with a meter..put the checkbook away.
With a KNOW GOOD BATTERY, charged, with clean terminals and properly attached to the starter, you need to have someone attempt to start it while you check the small post on the solenoid with a light or meter. You need to know that Mr. Starter is being TOLD to start by the key switch.
Remember that "won't start" is a different animal than "won't charge". Don't replace anything more until you know what isn't functioning properly.
If it's a automatic, don't forget the neutral starter safety switch. All the items on the rig can be tested in place and proved to be good or NFG, then replaced.
Stuart | | |
#94195 01/06/2006 9:02 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Stuart... Is NFG what I think it is?  | | |
#94196 01/06/2006 9:13 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Brendan,
Probably tis my man!
Stu-rat | | |
#94197 01/06/2006 10:21 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Excusing my poor English, a family friendly translation is "Not Functioning Good" !! | | |
#94198 01/06/2006 11:12 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | truckernix, That is exactly what I meant..wow, a psychic. Stuart | | |
#94199 01/07/2006 10:11 PM | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | My buddies old ford had a similar problem. good battery, starter, alternator. but what it ended up being was the coil, all i did was loosen the screws on the coil and scuffed all the contact pints with sandpaper. when i reassembled it everything worked perfect. this was after he replaced a perfectly good battery and starter against my advice. anyway i would say to try the coil and see what happens, nothing to lose.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | |
#94200 01/10/2006 10:12 PM | Joined: Nov 2005 Posts: 16 Junior Member | | Junior Member Joined: Nov 2005 Posts: 16 | Thanks for all the replies, Will post, when I get it goin.
Patrick | | |
