7 members (Gdads51, Lightholder's Dad, ShopRag, Hotrod Lincoln, sudsyz, Chip O, 1 invisible), 77 guests, and 0 robots.
Topics128,210
Posts1,057,456
Members48,471
I have a modest leak where the torque tube connects to my old crash box. It looks like it would be a seal or gasket. How difficult is this to repair? Anyone have advice or part numbers? I haven't found much info. by searches and vendor catalogs.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
Is your leak here?
...here...
Or there
...there...
Or both (like mine)
Dads50, it is "there" for sure but my tube extends further down to a carrier bearing for the open driveline. I found in a parts book a seal (OEM #348259)referred to as the "universal joint ball collar seal".
I found an illustration of your "here" photo which describes a cork or felt packing washer depending on year. Mine is unique since it is for a 3/4 ton, the part on mine is at the center carrier where the torque tube converts to a drive or open propeller shaft. There is a bearing in the center carrier with an oil seal. Not sure, but for me I think it calls for a 2-19/32"ID seal with OEM #3653618 (Update, I found an interchange part at RockAuto, SKF Part # 25970.)
I'd like to know what the modern parts numbers are, where to get them, and what to expect when repairing them.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
the fel pro number for the ball collar cork seal I used on my 1/2 ton is felpro es-72843
...pic...
(steel washers not included)
although I'm not sure if it the same kit for your big bolt.
Maybe some can advise?
Denny has some good info on his web site for the carrier
...denny web site...
After my first attempt at a repair I still experienced a small leak.
good luck
hopefully someone can give you a kit number
Thanks! I forgot how thorough Denny is with the pictures. He has the 3/4 ton too! By the way, on your pictures I noticed a grease zerk on the cast member that the bell housing attaches to. I thought the all the innards there used the tranny gear oil?
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
yeah
the fitting has been on there ever since I don't know. It servers no purpose.
your right about how it gets lubed.
I going to leave the zerk there just to stick it to the establishment. cool
