4 members (chevyb, 1955 1 Series, Otto Skorzeny, Hotrod Lincoln), 110 guests, and 3 robots.
Topics128,076
Posts1,056,008
Members48,433
#940777 05/04/2013 10:46 AM
so I have couple 58 Apache monojets to rebuilt and one for a 53 GMC. Under the carbs on each is an insulator, that is cracking on most all of them. I know the resto shops carry them, but surely there is a factory part number I could find something local (at a napa or something) this weekend? anyone got a part number? LMC lists them as 32-3912, ecklers lists them as 129207, but somewhere there must be a factory part number, would seem these commonly need replacing due to cracking/vacuum leaks??? trying to get a truck going this weekend if I can, most chain stores can order and get in a day or so if you have part number
1 Offline
If all else fails, Install the carb with a carb to intake gasket and get your engine started. Just initial start-up will not be affected at this point. Install the insulator at a later date when you get ahold of one.
I have been running Mono-jet's for years with out them. My truck never gets hot enough to boil fuel in the carb, which the insulator prevents.
Joe
I doubt you will find one of those at a parts store, you can just forgo the insulator for now, and get one later.
