8 members (Stewart2, 3B, Peggy M, Steelonsteel, moparguy, Millenimech, 2 invisible),
100
8
Mod | | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | so I have couple 58 Apache monojets to rebuilt and one for a 53 GMC. Under the carbs on each is an insulator, that is cracking on most all of them. I know the resto shops carry them, but surely there is a factory part number I could find something local (at a napa or something) this weekend? anyone got a part number? LMC lists them as 32-3912, ecklers lists them as 129207, but somewhere there must be a factory part number, would seem these commonly need replacing due to cracking/vacuum leaks??? trying to get a truck going this weekend if I can, most chain stores can order and get in a day or so if you have part number | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | If all else fails, Install the carb with a carb to intake gasket and get your engine started. Just initial start-up will not be affected at this point. Install the insulator at a later date when you get ahold of one. Jerry
| | | | | Joined: Feb 2000 Posts: 5,213 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,213 | I have been running Mono-jet's for years with out them. My truck never gets hot enough to boil fuel in the carb, which the insulator prevents.
Joe | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I doubt you will find one of those at a parts store, you can just forgo the insulator for now, and get one later. | | |
