1 members (1 invisible), 46 guests, and 2 robots.
Topics128,043
Posts1,055,610
#940430 05/02/2013 10:46 PM
I had my 60 full flow 235 drilled for a remote oil filter. I mounted it to the fire wall and connected black rubber lines. They are approximately 30 inches long. Not sure if I like this look.
Does anyone have any pictures of filter placement? If yours is on the fire wall what type of lines did you run?
Dennis
I put mine on the side of the engine block with a bracket I made. I used an fittings and black braided nylon -8an hoses. Looks clean and simple. I'm still waiting on my line clamps that should be here soon to tidy the lines up a bit.
http://i138.photobucket.com/albums/q268/cotsi95/chevy%203100/photo1_zpsdda73df2.jpg
http://i138.photobucket.com/albums/q268/cotsi95/chevy%203100/photo2_zpseb26ca49.jpg
http://i138.photobucket.com/albums/q268/cotsi95/chevy%203100/photo3_zps7c593e84.jpg
52' Chevy 3100 5 window
On a 1960 261 that has 1/2" NPT fitting and lines for the standard full-flow oil filtration system, I have used the factory canister full-flow oil filter mounted on an original intake manifold (forward to the carburetor), a remote spin-on filter head mounted on the firewall, and a remote filter head mounted on a custom-made plate attached to the side of the engine.
I went to the after-market spin-on filter heads because the stock canister filter could not be mounted on the dual carburetor intake manifold. For the after-market spin-in filter-heads I chose locations where I could easily and cleanly take off the filters.
In the next few weeks (I hope), I'll be putting the original full-flow canister filter back on the original intake manifold (using a single two-barrel carburetor).
Thank you for the pictures. I really appreciate them
Dennis
wish I could figure out how to post pictures, I did mine in very shiny copper, I'm kind of leery of it, but that is what they used for the rocker arm oil line, but at least this is where you can see it if it starts to leak.
The problem with copper lines is that they can harden do the vibrations and crack. That's why I went with -8 an lines. However it's quite a bit more expensive. I think I have 80-100$ in the fittings and lines.
The real reason I'm not extremely worried is they are only about 8 inches long, and there isn't a straight portion to vibrate. I will take a photo, and see if my wife will help me with the pictures. I'm actually kind of proud of my tubing, it only took 3 tries to get it right.....
Where did you get the lines? I was quoted around $200 for both if they are 30 inches long. Is that right?
Dennis
If your asking me I got my parts off summit racing. I just got the adapters I needed along with the fittings and 6 ft of an line. Then cut and made them myself.
