| | | Forums66 Topics128,139 Posts1,056,454 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 17 New Guy | | New Guy Joined: Sep 2011 Posts: 17 | I need clarification of the bolts that attach the transmission to the engine. My truck is a 66 long bed with three on the tree. There is an oil leak thru the front and rear oil seal and I am planning to replace them but I want to confirm that the transmission is attached to the engine with four bolts. The problem is that the two bolts at the bottom do not have head, and they are with a smooth surface that I have a doubt if those two at the bottom are bolts. Please advise.
Waddie | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | The lower 2 transmission holes are threaded holes and the bolt head is inside the bellhousing. These pics should help. You need to remove the dust cover to get to them. Pic one - PS tranny to bell bolts Pic 2 Pic 3
| | | | | Joined: Sep 2012 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 28 | There are four bolts holding the transmission to the bellhousing, the lower two go through the bellhousing and thread into the tranny.
Also there are are six bolts holding the bellhousing to the engine, but I would not remove them unless you have to as the bellhousing supports the back of the motor.
1963 Chevy C30 - 292 I6 +.040" 10.78:1, SM465 1978 GMC K2500
"Four gears with a granny low and six cylinders straight in a row."
