7 members (jmoore, kades51, Otto Skorzeny, TexasA&M48Truck, Frank50, Jon G, 1 invisible), 74 guests, and 1 robot.
Topics128,132
Posts1,056,379
Members48,441
#94068 12/29/2005 2:58 AM
Junior Member
Junior Member
Does any body know if the sender wires to the smaller or bigger pole on the gauge? thanks Jay
Life expands or contracts in direct proprtion to your courage
I.I.# 4754
#94069 12/29/2005 4:50 PM
Big Port,
In an effort to leave no post unanswered, I will give you my unprofessional opinion. I looked at a wiring diagram for your truck. As would be expected, it showed wire routing but no dope on the gauge.
If there are four posts on the gauge, would the two that are wire terminations have small visible insulation washers on them where they penetrate the back of the gauge. Could the others be used for holding the gauge in the dash.
These are obvious conclusions, so I would assume you are still stumped. Good luck, and great handle.
Stuart
