0 members (),
166
Mod | | | Forums66 Topics128,196 Posts1,057,386 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 12 New Guy | | New Guy Joined: Apr 2013 Posts: 12 | I am located in south central Michigan. Does anyone have, or know of a place to find parts for a 55 panel in this area? I am looking for a right fender, as well as patch panels for the quarters.
Any advice will be greatly appreciated. | | | | | Joined: Dec 2010 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 62 | first or second 55 ? I've been fabbing mine out of pickup bed scraps. | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | Try Ray Stanley for the patch panels for the quarters. [email protected] | | | | | Joined: Apr 2013 Posts: 12 New Guy | | New Guy Joined: Apr 2013 Posts: 12 | hotshoe... second Murray... thank you, I will definitely be sending him an email.
| | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Hu99;
Are you talking about patch panels for behind the rear wheels? If so, please post details if you get anywhere with the source recommended above. I am very interested in patch panels also. Haven't been able to find a source for panels/suburbans yet.
Larry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Ray does AD panel body pieces, but last I heard he doesn't have any patterns for the TF bodies, but if you can supply him a good pattern he'll duplicate it perfectly
Bill | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Bill;
Hooah. Thanks. Where is Ray located? Would be nice if it was close by.
Larry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | tech tip he did, Wheelwright, Mass Bill | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Bill;
Hooah. Thanks. Looks like he does nice work. I may contact him if I can't find another solution.
Larry
| | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | I cut the wheel openings out of two step side fenders and welded them in place. I also had to make panels for in front of the wheel openings, and behind. I used the lower rear corners of the fenders for the rear corners of the body. It is not great because there are lots of welded seams, but I am happy how it turned out. Here is what it looks like. I learned from Stovebolt that the step side openings are the same, fleetside are not. Good luck! | | | | | Joined: Nov 2012 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 77 | Major progress IMO.
So, you cut the bad out of the panel, then matched with donor sections?
| | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | Yes, the previous owner had pop riveted in aluminum flashing and built it up with long strand Bondo. As you can imagine, it looked awful. I also bought rocker panels and welded them to the bottom of my patch panels. So on each side I had: front panels made of 20 gauge hot rolled sheet metal with a rocker panel welded to the bottom. Behind that the donor section, then a patch panel made of 20 gauge connected at the bottom to the donor fender corner. | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Not sure about Bill Wales in Carleton, Michigan. The person I purchased my panel from dealt with him. | | | | | Joined: Jun 2009 Posts: 1 New Guy | | New Guy Joined: Jun 2009 Posts: 1 | im in central ill and have made quarter panels for my suburbans if you want call me sometime ill try and help you out 618-347-2427 thanks | | |
