8 members (MikeE, Bucker, MickeyP, Rexville48, dt235sd, Forty9, David Bush, kades51), 89 guests, and 1 robot.
Topics128,049
Posts1,055,702
#940316 05/02/2013 1:22 PM
Hi All,
I have an 11" flywheel out of a 59 3 ton farm truck that I'm trying to get resurfaced. The machine shop guy says everything he finds says its supposed to be flat, but to make it flat, he will have to take quite a bit off. Can anyone tell me if my flywheel is supposed to be "stepped".
Thanks.
Joe
PS I'm not even sure what "stepped" is....
#940317 05/02/2013 1:23 PM
Hi All,
Thanks.
Joe
Joes41 #940320 05/02/2013 1:39 PM
What transmission and engine?
Are they original?
Joes41 #940321 05/02/2013 1:40 PM
Joes41 #940325 05/02/2013 1:45 PM
not with the amount of info so far...
What make of Farm Truck is it?
What engine is it?
What transmission is it?
Give me ambiguity
or give me something else
CASO #940327 05/02/2013 1:48 PM
Sorry, it's a 261. As far as I know it's all original.
I don't know what model farm truck, just that it was a "farm truck".
I'm putting the 261 in my 41 sedan with a T5.
The machine shop has the "disc surface" flat. He estimates he'd need to take another .007 off to make it flat all the way across the flywheel.
So if it's "steeped", its not much of a step.
What's really bizarre to me is, if it is worn, why is the disc surface higher the the outer surface?
Joes41 #940391 05/02/2013 8:08 PM
a picture would be wonderful
Joes41 #940680 05/03/2013 10:16 PM
Twin disc clutches have a dished flywheel, but I've never heard of a stepped flywheel and I've been around trucks 3 ton and larger for over 50 years.
Thank you sir.
