3 members (Ponchogl, DadsFirstPickup, Otto Skorzeny), 204 guests, and 5 robots.
Topics128,107
Posts1,056,225
Members48,436
#936713 04/18/2013 6:05 PM
I'm having it done cuz I don't have the skill...just the way it is. I went to the shop to see the guys. They told me that the power brake booster and MC will not fit w/o mods to the cross member because I have a stick shift... ?? This sound right to you guys ?
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
yes,they are correct,(btw, it's the bracket, not the crossmember). why not put in hanging pedal system? my $.02.
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
http://www.doublegcustoms.com
Alvin(Achipmunk) and I had the same problem,although i'm using a TH350C trans,what I had to do was cut and rotate the left hand side to clear the booster.
Trans crossmember/booster clearance.
More pix on Flickr.
Yes, hanging pedal bracket assembly with firewall mounted booster/master cylinder would be more appropriate for your application.
I used a the CPP set up. Bullet proof construction, easy install, and great brakes.
my 2 cents, too!
mike
Thanks Guys.. It's done now...just had to mod the bracket and cross member a bit. I was in favor of the fire wall system myself...easier to ck fluid...but I got the booster and MC with the package from TCI. I'll put in an access door I guess.
Mark
1949 Chevy 1/2-Ton
Lucielle
What is "the CPP setup"???
