1 members (Ole49GMC),
109
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I'm having it done cuz I don't have the skill...just the way it is. I went to the shop to see the guys. They told me that the power brake booster and MC will not fit w/o mods to the cross member because I have a stick shift... ?? This sound right to you guys ? | | | | | Joined: Apr 2008 Posts: 133 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 133 | yes,they are correct,(btw, it's the bracket, not the crossmember). why not put in hanging pedal system? my $.02. daren | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Alvin(Achipmunk) and I had the same problem,although i'm using a TH350C trans,what I had to do was cut and rotate the left hand side to clear the booster. Trans crossmember/booster clearance.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Yes, hanging pedal bracket assembly with firewall mounted booster/master cylinder would be more appropriate for your application. I used a the CPP set up. Bullet proof construction, easy install, and great brakes.
my 2 cents, too!
mike
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Thanks Guys.. It's done now...just had to mod the bracket and cross member a bit. I was in favor of the fire wall system myself...easier to ck fluid...but I got the booster and MC with the package from TCI. I'll put in an access door I guess. | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | What is "the CPP setup"??? | | |
