0 members (),
125
10
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | Ok I have a gap on the seam that runs around the back of the cab. Wondering how that really should look.
FIlled in or 1/8th inch gap ?
Anyone have any good pictures of that?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that was recently discussed someplace here - fill it with paintable flexible seam sealer and 'trowel' it concave so it's not visible from above or straight on, paint over it
Bill | | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | well that filled the gap - but looks like crap. In my opinion - not very uniform | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well, the uniformity will be under the control of the applier, and practice makes perfect  Bill | | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | The stuff is not the easiest to pick out - did that already once. will have to sleep on it and see if I give it a go once more.
I saw a thread somewhere where someone used a cut piece of a liter bottle - may try that | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, find something, preferably smooth plastic, that is barely the size of the gap and use that as a tool to 'trowel' it smooth - will usually help to wet the tool first and do not stop/start, get in a good position to run along at a smooth steady rate the full length of the seam
Bill | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Not supposed to be anything in there, I used a dentists dental pick to scrape mine out. The dentist throws those away so ask if you can have yours when you go. Anything you try to fill it with will eventually fail and crack the paint. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Vern, what does the assembly manual specify? I recall the previous discussion saying the factory did use sealer in there
Bill | | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | Section 14 sheet 9 states it should be sealed with sealer and a 1/16 nozzle and wiped smooth.
