7 members (MRMEROTH11, FAST55, Otto Skorzeny, Hotrod Lincoln, carbking, TUTS 59, Joe H),
86
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,051 Posts1,055,768 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I purchased one of these repo lighters ....pic.... I will only be using it to charge the phone. Should I fuse protect the hot side? Plan to grab power off the ignition terminal that's always hot If a fuse is recommended, what size? Thanks Oh. Non smoker so I don't think I would ever charge the element | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | fuse it for the rating on your fone charger, chop off the element so the handle is just a plug for the hole, no smoking allowed  Bill | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thanks
Is there a special terminal for the back of the lighter?
The terminals I have on hand have to be bent back because of the deep well as you can see in the pic,
then I can't get my socket in to tightened..
I know this must be easy, Must be obvious I'm just not seeing it.
Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yeah, poor design, can't think of any terminal that would work there - you could wind a couple turns on the end of the wire [bare], solder that well to make a fat loop and use a brass washer between that and the nut .... but I think I'd cut a piece of copper tube that fit snug on the post and nut it on so there's just enough thread left for a crimp terminal, star washer and another nut [all brass hardware] .... I'm from the creative school of electricians  Bill | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thanks for the ideas I have some brass nuts in the garage, I used your suggestion and moved the mounting pont out ...pic... ...pic... Nothing is ever just easy....is it Thanks | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Gus - I used a standard insulated terminal and bent it as you describe. I always solder terminals. I don't remember how I tightened the hex nut to hold it in place. Probably with some needle nose pliers. I used an in-line fuse, so I could tighten the nut before I installed the lighter socket into the dash. Then connect the two parts of the inline fuse after the ligher is mounted. The in-line fuse protects the lighter and the heater fan. Power comes from the switched side of the ign switch. > Lighter terminal- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thanks
Looks like you have a little more room in your housing than this counterparts thing I bought. I tried that terminal first. It just was not going to happen.
Did you not have to hook up the ground lug?
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I am thinking of using a fuse box/block from a 53 3100. It has two fuses. One for the directional signals and the other for the cigarette lighter.
I want the lighter electrical portal for either my cell phone or a gps unit (garman).
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Gus - The lighter was in the truck when I bought it 13 years ago. Don't know what kind. It's not original because there is no light bracket. Also, I believe that 6v lighters were a little larger diam than 12v. My truck has been converted to 12v. I just use it for my phone. It does have the correct knob according to Jim Carter. > Cigarette lighter knobDon't know why I didn't hook up the ground lug while I was rewiring it. Works fine without it. Must be some bare spots on the dash where it attaches. - Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Same here
Just want to charge the phone
Got it installed and tested. No such thing as a 10 minute job on these trucks. Thanks all for the help.
My truck did have a lighter at one time. I remember it as a kid riding with my Dad.
He smoked and crushed a few cans. It was the early 70's ....fond memories | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | DAD550 The lighter base you have is a standard replacement for any car/truck. You need the following connector which was made for this type hook up (threaded screw). It just pushes on and will not fall off. It is insulated and is the eaisest connector I have ever used. It is AIRTEX Part # 1P1063 You can get it from O'Reilly Auto Parts http://www.oreillyauto.com/site/c/search.oap?keyword=1p1063+[/color] Rock auto parts also has it. http://www.rockauto.com/catalog/raf...partnum=1P1063&a=FR903-1P1063-856074Check Ebay or just Google Airtex 1P1063  Harold
Harold Is a restoration ever finished? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 |  Thanks. That is good info. That terminal on the back is a pain. They should sell the boot with it. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | DAD550, I forgot to mention in my previous post, I get most of my connectors from cars in the junk yard. Just be sure to cut the wire long enough to splice if you have too. Harold
Harold Is a restoration ever finished? | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Dad;
You must not have read my post about my first electrical fire.
Absolutely use a fuse!! My cheap aftermarket lighter/power plug shorted out and smoked the power wire. I'll be installing a battery quick connect switch and fuse when I put another one in. I had to jump out and disconnect the battery when it went up in smoke.
I think the original lighter used a 20 amp fuse. For just a GPS and or phone a 5-7 amp should be good.
Larry
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thanks Yes I did install it with a in line fuse. 10a I also picked p a booted connector for the lighter, It was suggested above. The charger worked well on my recent trip, charged the phone for an hour at a time. I did notice the charger was a slightly warm to the touch a the lighter. I think it was a litte heat getting past the ceramic base. I might look into a better quality lighter If there is one out there. Maybe an old original. ...pic... Thanks | | |
