| | | Forums66 Topics128,049 Posts1,055,677 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Does the 261 use the same oil pan as the 235?
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year(s)?
235/261 54/55st are the same (and 235 1953 Powerglide engine) 235/261 55-2nd and later are the same
| | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | In my case 1958 so looks like I need to find a second generation stovebolt oil pan.
Thanks!
-m-
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Make sure you use the matching oil pump pickup. There were 3 changes in the pickup. 1955-57 1958 1959-62
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Make sure you use the matching oil pump pickup. There were 3 changes in the pickup. 1955-57 1958 1959-62 Can a pick up still be had new or will I need to find a used one as well?
