| | | Forums66 Topics128,083 Posts1,056,326 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Just curious if anyone has an idea if my 6 miles to the gallon is good or bad? It's running just fine. I have not been caring anything heavy for any length of time.
Seems like a 6 cylinder should get a little better? | | | | | Joined: Jan 2013 Posts: 1 Moderated | | Moderated Joined: Jan 2013 Posts: 1 | I average about 17 mpg with my 1950 6400 On a trip from Denver to my home in Montana (650 miles) with about 5000 lbs. on I averaged 17.6 mpg. But the 235 is not stock
Another Day In Paradise
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Thats about all you can expect. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Randy, sounds ballpark to me considering the rear ratio you'll have, but if everything is well tuned you might get a wee bit better and welcome to the garage gg, you'll need to give us a lot more data about that modified 235 that gets better mileage for your 6400 than a 3100  Bill | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | Have a 270 that runs sweet as can be, but I only pull about 9mpg empty. Havin really low gears in the rear end doesn't help my mileage, but at over 9,000 lbs dry weight there's a definite difference between too much gear and not enough to do the job, so there's a trade off. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | its intersting this came up i was just checking mine last week in the dump. 40 mile round trip hauling stone. 3.5 tons in box mpg one day was high sixes and the next day just under 3.5 tons was low sevens. no flat road so to speak of all down hill empty and all up hill loaded. when i used to check it some time ago it would get high sevens to low eights empty. the ashton gets low sevens to high eights tare wt 11000. lbs no water the dump 7300 lbs empty the 40 gets 13.5 on a all out flat run for 650 miles to south bend and back 4400 lbs. empty I average about 17 mpg with my 1950 6400 On a trip from Denver to my home in Montana (650 miles) with about 5000 lbs. on I averaged 17.6 mpg. But the 235 is not stock i dont believe that for a second. recheck your math. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | On several thousand mile road trip in my 52 1 ton with a 235 I got in the 12-15 neighborhood. 17MPG in a heavier slower truck with 2.5 tons load in it is a dream. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Grigg, I agree with you, but I think Ashton's statement sums up my sentiments on the matter a little better. We ran GMC 350 and 450 tank wagons in the 50's and 60's. 6 is a good average number and it could fall from that with a cowboy driver. | | | | | Joined: Jul 2008 Posts: 86 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 86 | When I picked up my 1964 GMC 4000 with 305 V6 I averaged 9.9mpg at 50-55mph and 10.1 at 45-50mph during the 480 mile drive home, all highway and state routes. Truck weighed about 10,000 with an empty 1200 gallon tank bed then. It now weighs 7900 with a 12' flatbed. I haven't checked in-town mileage but it is probably 5-6.
| | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | 9 MPG with flatbed, got 10MPG once | | |
