| | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93953 12/19/2005 4:10 AM | Joined: Aug 2005 Posts: 43 Junior Member | | Junior Member Joined: Aug 2005 Posts: 43 | Hello; My 1954 3100 has a condenser on the coil that I believe is to help keep static type noise out of the radio. I don't know which post of the coil it should connect to. I assume it connects to the ignition switch side and not the distributor side. Right? Also, will any condenser work? Thanks in advance for your advice. Rich | | |
#93954 12/19/2005 7:04 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | IIRC, the only condenser is in the dizzy. You've probably got a resistor on your coil; it does go onto the ignition key side.
Do you have a 12v or a 6v system? If it's a 6v setup, then you don't actually need it. If it's 12v, you do. It will help your coil last longer. | | |
#93955 12/19/2005 7:17 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there is an anti-static condenser on the coil for the radio, as well as one on the regulator, one on the generator, one in the hi-tension coil wire, and antistatic doobies in the front hubs - originally!!
original #'s: ignition coil capacitor (No. 1929070) [+ term] generator capacitor (No. 1911095)[arm term] voltage regulator capacitor (No. 1917580) [batt term] so it looks like, NO, any ol one won't do
prolly all unecessary if yer radio is A-1 or if you use a modern radio - they mostly got scrapped soon when any work was done on the part they're attached to
Bill | | |
#93956 12/19/2005 11:18 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It hooks to the pos. side of the coil that goes to the switch or resister. An ign. cond. will not work. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#93957 12/19/2005 11:57 PM | Joined: Aug 2005 Posts: 43 Junior Member | | Junior Member Joined: Aug 2005 Posts: 43 | Hi to all; Thanks for the good information. It is much appreciated. I will search out the correct part. Rich | | |
