| | | Forums66 Topics128,157 Posts1,056,872 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93936 12/17/2005 8:44 PM | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | I am trying to keep my pedal start and convert over to 12 volt with an HEI. I got the mini HEI and coil from Langdons and am not sure how or if you even can switch it. The trucks current state is just a rolling chasis and driveline. Has anyone done this and can you help/explain how it works. I have been told that you can't buy new ignition switches and the one I have was the stock one with the metal wrap to the bottom of the stock coil. I am currently just lost. Thanks for any help.
1946 1/2 ton I'm not addicted I just don't know when to stop
#93937 12/17/2005 8:59 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | You don't need to lose your original starter pedal! I'm using the mini hei from Langdon's in my 46 pickup 261 motor works great. I kept the original 6 volt starter and floor pedal linkage as only starter trouble I've had was the solenoid. Tom sent pretty detailed sheet of instructions. States you need a #10 size wire to the new coil from ign switch, per supplied drawing. I also went with a new set of Ford 300 six ign wires. Let me know if you need any other info or help I could take dig photos if needed. | | |
#93938 12/17/2005 9:35 PM | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | Jim, Any pictures would be great. Did you just run a new wire from your ignition switch and how did you attatch it to the coil?
#93939 12/18/2005 4:20 AM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | little horse, Send me an email and I'll send you a photo. | | |
