0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93926 12/17/2005 4:57 PM | Joined: Dec 2005 Posts: 45 New Guy | | New Guy Joined: Dec 2005 Posts: 45 | I'm going to change my 54 235 over to 12V and convert the point to the Pertronix. Would it be best to also use there coil for 12V or is there a different coil I should go with. Also, I'm not that familur with how it is wired up with a resistor or with out? Which way is best?
thanks, | | |
#93927 12/17/2005 5:32 PM | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | Check Patricks web site, they have a tech article with everything you need to know, also links ond tech on this fine website as well!! Smitty | | |
#93928 12/17/2005 6:50 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I just did the same thing on a 54 pass. car. I used a salvage 12 volt coil with a new resister. It starts instantly. The intruction sheet tells you how to wire it. I ran the original wire to the coil to the resister & a wire from the resister to the coil & wired the petronics acording to the intruction sheet. This does not provide a resistor bypass but i don,t think we are going to need it. The reluctor that came with the kit did not fit tight on the dist. shaft so I called & they sent one that did. I am very pleased with it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
