| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | I have a 1956 car 235 in my 1593 3100. The intake manifold casting # is 3836922 and head casting # is 3836848. I want to switch the intake to one with the mounting tab for the horn. I see one on e bay with casting # 3835590, seller not sure if for a 235 or 216. Do you think they are interchangeable? And are the gaskets for the intake/exhaust seperate or one piece. I know I'm going in way too deep for just a horn bracket but I can't help myself!!! Thanks, Paul | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Have the seller measure the intake port for you
If its 1 1/2 you should be good
If its 1 3/8 it's most likely 216 or early 235 You could still use it but you will need the exhaust with it and the carb spacing will be smaller, so you will need the carb for that manifold.
Also check how the exhaust flange runs, some will run straight down, make sure it matches what you currently have.
Others will be along to correct any errors I made
Good luck | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I have a 1956 car 235 in my 1593 3100. WOW! Chevy's older than I thought it was.
| | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | Oops, 1953. Thanks Tiny and Dad's 50 | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | And are the gaskets for the intake/exhaust seperate or one piece. I know I'm going in way too deep for just a horn bracket but I can't help myself!!! Thanks, Paul The gasket at the heat box is not the same ...pic... As you can see in the pic you cannot mix (exception early 235) The gasket to the head should be the same for both. | | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | Seller says port is 1 3/4 ", but thinks it came out of a 1949 -1952 chevy truck. But casting # is 3835590 for sure ,I can see it in the picture. Doesn't that make it a 1950-1955 235 manifold? Thanks | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Seller says port is 1 3/4 " Sounds like it may be GMC
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | So do you folks think it will work on my 1956 ( I think) 235? Thanks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I believe Denny Graham has that manifold on his 54
Maybe you can P.M. Him for definitive info. Also The seller may have mis measured
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Paul, My 1954 3104 has a 3835590 intake manifold and it has the mounting tab for a horn. The 235 truck engine block was cast February 26, 1954. It has a 3836848 head that was cast December 22, 1959. I have not had the manifold off of the engine since I have owned it, so I don't have any measurements or other info. I found that it was painted yellow when I stripped off the top layer of paint so it may have come from a 261 engine. According to Robert Hensel's research, 1955-1957 261 cu in engines were painted yellow. Group #3.265, part #3694163 in the 1929-1957 MPC is an intake manifold with casting #3835590 "50-57 All 6 cyl. (exc 216, D.D., COE); 57 D.D (2 Ton)". > 1929-1957 MPC: Group #3.265, part #3694163> 3835590 intake manifold> Yellow intake manifold> Yellow 261 engine color info- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | |
