1 members (1 invisible), 78 guests, and 2 robots.
Topics128,034
Posts1,055,546
Members48,425
#939185 04/28/2013 9:25 AM
my 216 i my 46 started running rough like it has a miss and it runs good when the idle is up high but when idling it runs rough, any ideas would help,
hoozat #939208 04/28/2013 10:32 AM
First thing I would check for would be a vacuum leak
hoozat #939212 04/28/2013 10:41 AM
What Bolter2 said, plus hook up a vacuum gauge and set (adjust) the air fuel mixture to the highest vacuum reading. Or maybe you're just due for a complete tune up.
Brian
1955.2 3100 Truck
hoozat #939863 04/30/2013 7:05 PM
Can anyone tell me where to find info on how to adjust valves? Not the specs, but how to ?
hoozat #939869 04/30/2013 7:24 PM
hoozat #939902 04/30/2013 9:18 PM
Thank you, it's what I was looking for
hoozat #942414 05/11/2013 9:13 AM
I wanted to thank you guys for the suggestions on my 216 motor, i found the problem with my 216, after checking everything from points to plugs to vacuum leaks and the problem was??...BAD GAS!!!! It started right after I got gas at a local BP station, I since drained the tank of 10 gallons of gas, changed the filter and refilled my tank and no more problems..... now I have 10 gallons of weed whacker gas, and now Im gonna have to work on the lawn....dammit
